Hi all.
I just bought a pair of TeamGroup Vulcan Gold 8GB (2x4GB) 2133Mhz (these: http://www.overclockers.co.uk/showproduct.php?prodid=MY-036-TG ) as I needed more than my current 4GB to be able to not have Photoshop running out of memory.
Reading online I thought that I should be able to use them on my old MSI G41M-P25 mobo on which I have an Intel Core 2 Duo E8400 OC @3.7Ghz, even though I knew that they would run downclocked at 1333Mhz. I went for 2133Mhz as I want to upgrade the motherboard and cpu in the coming months and I wouldn't have to buy new RAM later this way.
The problem is that with the new RAM my PC doesn't boot, not even able to get into the BIOS. It makes 3 beeps (memory error as I've read) and that's all.
Looking in the BIOS with the old memory in (2x2GB Samsung @1066Mhz) my motherboard supports the required voltage of the Vulcan's (1.65v) and as for FSB it can go up to 333Mhz.
I tried upping the voltage with the old rams in (kinda risky but tried it nevertheless) to 1.65v and then swapped with new ones but that didn't work either. I've reset CMOS, tried all the values on the FSB switch but nothing works.
Does anyone have any idea why they wouldn't simply work at lower frequency (1333mhz) and have the motherboard auto-adjust the voltage to 1.65? On the Vulcan's page it even says (1.55v - 1.65v) so it shouldn't even need 1.65. Current RAM runs at ~1.53v, OC'ed to ~1293Mhz with 323Mhz FSB and has been incredibly stable for the past year.
Sorry for the long explanation.
Best regards,
Mihai
Best regards,
Mihai
, and funnily enough, the difference with this new update is that my CPU fan runs constantly at 2900rpm now. So loud...
