RAM cooler modification Help
16 Dec 2009
Bolton
Well as you can see below I have a white theme going on here and my RAM cooler's Fans are kinda ruining it.
As you can see they are blue, what I have in mind is switching the fans too white one's. I can easily remove the fans but the only problem is the connection. Currently both the fan pins connect into a small slot which is mounted on a small PCB attached to the RAM cooler. The problem I'm having is One of the two fans has 3 wire as any normal fan would but the second one only has 2 wires.
Well my problem is if I were to buy 2 new fans they would both have 3 wires each now assuming they will need all 3 wires to work how on earth can I replace two fans in this RAM cooler?
installing photoshop now to draw what I mean. I would take pictures but I don't have a camera for the next 5 days.
