26 Feb 2011 at 18:08 #1 Zeebedy Zeebedy Soldato Joined 28 Jan 2011 Posts 8,535 Hey, I have just overclocked my 2600k to a modest 4.2GHz. The problem is the DRAM is showing 668.9MHz Is there something not right with that? I have the ASUS P8P67 MB. RTJ
26 Feb 2011 at 18:10 #2 RJC RJC Don Joined 29 May 2005 Posts 29,080 Location Kent What memory are you using as you probably need to manually adjust in the BIOS, if your using 1333mhz then your fine.
26 Feb 2011 at 19:09 #3 Zeebedy Zeebedy Soldato OP Joined 28 Jan 2011 Posts 8,535 Hmm, its 1600mhz so should I set it to that in the BIOS? RTJ
26 Feb 2011 at 22:22 #4 RJC RJC Don Joined 29 May 2005 Posts 29,080 Location Kent Yes, You should hopefully increase the memory multiplier.
1 Mar 2011 at 17:37 #5 DennisMenace DennisMenace Associate Joined 7 Sep 2010 Posts 531 Set it to 800Mhz, Don't forget it's Double Data Rate!
