Try changing the mem timmings in the bios to CAS 2.5. should get 250fsb out of them but the cpu may top out before then with out good coolling.
Try cpu multiplier x11 with 250fsb should give you 2750Mhz if stable work upto fsb 253 =2783.00 MHz if that works then you will know that the ram was not the problem at more than muti x12 at 232 fsb.
Even tho your not going above 50oC the faster you push the cpu the colder the cpu needs to be in most cases, so if it was stable at 2.4GHz at 50oC it would not be stable 3.0GHz at 50oC.
