Ram for DFI expert
19 Jun 2004
On the Amiga500
Hello again.
I posted a while back about RAM for an Ultra-D, well I never actually got the ultra D but ended up with a DFI expert instead :cool: I've thrown an Opty 146 in there and Im currently running 1gb OCZ PC3500. Currently clocked it to 275x10 but my memory is on a low divider, 2/1.4 I think.
Im about to order my new set of RAM and assuming I'm best with a set of BH5, perhaps some OCZ platinum? Can you guys recommend me which to get to best overclock this system, IM quite clueless :cool:
thanks in advance
2Gb or 1Gb? Finding some TCCD/BH-5/UTT for 1Gb
I have some sticks that do 300 2.5-4-3-7-9-14 @ 3V, and probably could do tighter - Put away for when I needed a bench pair - 2Gb 2.5-3-2-5-7-12 @ 230Mhz @ 2.9V G-Skill ZX has replaced them.
Just depends on what you want to do.
Well its mainly for visual, i.e. DVD's, encoding and high spec games so I want to get as much as I can from the CPU and I'lll soon be upgrading to a x1900xt so I dunno, what do you suggest? :D
Gskill 2Gb ZX
Cheap, tight timings, clocks well :)
Minstadave said:
Gskill 2Gb ZX
My Expert isn't liking my ZX at the moment.....
(worked great in the Ultra-D though)
Will keep you up to date. Got a day off tomorrow so guess what I will be doing ;) (litrally just installed windows :))
