- 29 Dec 2022
- Wales
Afternoon all,
My wife kindly bought my 4 x 8GB Team T-Force XTREEM ARGB DDR4 4000 MHz RAM for Christmas, whilst my system works it will not allow me to increase my RAM speed from 2400 Mhz and when I do try,the system resets it after trying to boot up 2-3 times. MY System Spces are as follows:
CPU: AMD Ryzen™ 9 5900X
RAM: As above
Motherboard: Gigabyte Aurous Elite x570
GPU: Founders Edition 3070 ti
Storage: 2 x 1TB SSD's
MY query is how can I increase my RAM speed to at least 3600MHz do I need to play wight timings and various other settings as well as manually changing the DRAM value? I appreciate this is not using the full 4000 Mhz but I don't think I will get to that and be stable. I have tried enabling XMP in BIOS and using Gigabyte Easy tune, both options caused the system to try and boot before reverting top 2400 Mhz speeds. The motherboard can take the RAM according to the QVL list but only as a single 8GB stick and not 4 x 8GB so could this be a compatibility issue with the MOBO? So far I cannot see any QVL lists that have 4 x 8GB compatibility and I don't really want to return these RAM modules as they look great and fit my system perfectly.
I would appreciate help and guidance on this but appreciate it may be new RAM is in the order but if I can solve it with help; I would rather do that.
Many thanks
Matt
RAM: As above
Many thanks
Matt
