- 24 Dec 2011
Hi all,
I wonder if any of you could help me, ive recently built a new system with pretty good specs but i have one problem.
I have 16gb of DDR3-1600MHZ RAM ( 4x4gb Kingston Genesis DDR3 1600MHZ), and i have had it installed for about a month or so and everything works fine, but the other day i took it all apart to clean my system and my ram was VERY VERY hot, now i know that running 16gb of RAM is a little OTT but i have got it so why not use it.
So i have them all in and when i took them out they burnt my fingers cuz they were that hot and ive searched all over the internet but came to no avail.
I have tried seeing if i could get a ram cooler but i dont think one would fit because i have a Crosshair V Formula motherboard and has only one set of ram clips.
Any help is appreciated ill put my specs below if it helps at all.
Thanks
Nathan Doyle
My Specs:
Motherboard-Crosshair V Formula 990fx AM3+
Processor-AMD Phenom 2 X6 1100T BE (3.7ghz OC was at 4.2 but high voltages forced me to downclock)
RAM-16gb Kingston Hyperx Genesis DDR3-1600MHZ (4x4gb sticks)
GPU`S- 2x MSI Twin Frozr II OC Gtx 560TI in sli
PSU-OCZ ZX 850 watt Modular 80+ Gold
CPU Cooler- Antec H20 920 Liquid Cooler
HDD`s- 2x Seagate Barracuda 1TB 7200RPM
Case- NZXT Phantom- Case fans listed below
CASE FANS BELOW
1 x 120mm on front to blow air in
1 x 120mm in bottom (where removeable hdd cage is) blowing upwards
2 x 200mm NZXT Red led fans installed at the top of the case blowing air upwards out of the case.
2 x 120mm fans on the side panel to cool hdd`s
All of these fans are hooked up to the motherboard to get better cable management rather than the installed fan controller.
Thankyou
Thanks
Nathan Doyle
My Specs:
CASE FANS BELOW
Thankyou
