- 27 Apr 2009
Hey guys, quick question...
I have a 5 year old Aldi Medion PC with a recently fried RAM chip for some reason, now that is DDr2 PC2-5300 or 6400 and it's about £30 to put 2GB of RAM into it to replace.
However my high spec system (see my sig) has 4GB PC2-6400 RAM and it seems to work out cheaper to replace the RAM for that as DDR3 than buy some older DDR2...
My question is I have a gigabyte GA-MA790FX-DQ6 motherboard and an AMD Phenom2 965 [email protected] I use DDR3 and if so what speed?
Cos DDR3 is cheaper than DDR2 so if i can get DDR3 in my newer system (maybe 4GB+) then I can use my current OCZ DDR2 in my Aldi system as the general family computer.
Any advice?
Thanks
Any advice?
Thanks
