RAM Help & Info
18 Aug 2018
Hi All I Have A MAX IV FORMULA I Have A Set of 4x 8gig Of CMK16GX4M2B3200C16 SO A SET OF 2 CMK16GX4M2B3200C16. Same Ram Same Set Same Numbers Same Timings 16-18-2T Running with XMP In Bios With 1.36v. In CPU-Z It Shows In The SPD Ranks That Slot*1 & Slot*3 Are In Dual But *2-*4 Are In Single Mode Is This Right If Not How Do I Go About Changing This
It should all be showing in dual channel, try turning off XMP and manually setting the speed + main timings.
