Hi everyone
im actually beat this time, i give up but before i throw it all out the window i thought i would ask for some help here.
system as follows
Asus Striker Extreme Mobo
q6600 2.4ghz quad core CPU
320gb Sata HDD
BFG 8800GT GPU
4 x 1 gb Gail Ram
dvd rw drive
pretty basic build to this point, i got the lot second hand from a friend who purchased all of the above from ocuk earlier this year and found the build to complicated...
anyway problem is with 2gb of ram installed vista will run fine. with 4gb installed vista (32 bit) wont boot (wont even install if its in there to start with)
have tested the ram, all checks out ok tested 2 at a time, with all 4 in its error city.
think maybe a bios setting is wrong but im out of my depth now to be honest.
all help and advice gratefully accepted
im running an AM2 / AMD system at the moment which is happy as larry with 4gb of ram so im totally confused over this.
system as follows
320gb Sata HDD
BFG 8800GT GPU
4 x 1 gb Gail Ram
dvd rw drive
can anyone give me a pointer on this i know it must be there
