Ram help
your RAM should be set to run at 2.1v, assuming your bios isnt to disimilar to mine (both being asus) there should be an option for DRAM voltage, prob on front page
Have you ran memtest already then?
What is the specific BSOD?
Memtest didn't throw up any problems, had the BSOD a couple of times, it was the IRQL LESS THAN EQUAL, but the last 24 hours its just been rebooting itself...
turn off automatic recovery, that way youll be able to get the full message, try googling the code, it should link you to ms tech help, if still no joy come back here and post, see if anyone here has had it b4
