Ram Help
31 Mar 2009
Stoke-on-trent
Mother board - RC410-M (Asterope)
it states that the max amount of ram i can put on is 2gb, however i was told that it would take 3gb with windows xp.
so i had 1gb, and thought i would add an extra 2gb.
It now only see's the 2gb chip, any idea if i can get it to see the other 1gb chip?
Cheers for the help in advance - not that clued up about pc's atm.
small update -
if i use CPU-Z to scan my computer it finds all 3gb of ram.
However using SiSoftware Sandra Lite 2009.SP2 - it only sees the 2gb chip.
i belive this to be because your motherboard can only use 2gigs of ram max then it sees your 2gig stick as 1 gig and the other stick.
cpu-z will see all the ram that is physically installed even though it is not actually getting used.
so my computer is only using 2gbs then?
new motherboard here i come :)
Have you checked for a BIOS update for the board, As an update may allow for more ram.
