RAM Issues
19 Apr 2010
Stratford-upon-Avon
Heya all, been suffering with some RAM woes for almost a year now. Been borrowing some off a mate now and its been running fine, but it's only 2x1GB and I really should be getting back up to 4GB (and giving him his RAM back!).
The problem I'm getting is the RAM will cause a BSoD, complaining about IRQL_NOT_LESS_OR_EQUAL.. I'm using an IP35 Pro mobo and supposed to be using 4x1GB of RAM made up of 2 pairs. They both have the exact same part number (OCZ2P800R22GK) but one is Platinum Edition (OCZ PC2 6400 4-4-4 @2.1v) the other is Platinum Revision 2 (OCZ PC2 6400 4-4-4-15).
I honestly have no idea what to do or what the problem is, I've tried MemTest and no problems reported there.. if there are any tests or bits of info you need me to do to help along with this then let me know!
Have a go of upping the MCH voltage (Northbridge) I needed around 1.35v on my board to run my memory at recommended settings.
