RAM MHZ / Latency - which matters more? sorry guys another question
21 Oct 2006
i was wondering which is better? for 2gb dual channel corsair
667MHZ at 4-4-4-4-12 latency
or 800MHZ at 5-5-5-5-14-t latency
quite the puzzler...
cheers muchly al advancio :confused:
gdev
You might find that they perform about the same. If you loosen the timings of the 667MHz RAM down a bit, you might be able to reach 800MHz with it. If you are overclocking, the extra speed might give you more headroom for overclocking without having to use a divider, but if you aren't then you might as well go for the DDR667 memory. :)
