RAM & Motherboard Compatability
17 Aug 2014
Hi
I know this might seem like a stupid question but i'm not 100% sure on the answer.
Would the AMD Gamer 8GB (2x4GB) PC3-14900C9 1866MHz Dual Channel Memory Kit (AP38G1869U1K) > http://www.overclockers.co.uk/showproduct.php?prodid=MY-003-AM
work with the following motherboard >
Asus M5A78L-M/USB3 AMD 760G (Socket AM3+) DDR3 MicroATX Motherboard > http://www.overclockers.co.uk/showproduct.php?prodid=MB-466-AS
If anyone can help that would be appreciated as I would like to order this morning.
Thanks
Stomps
No reason why it wouldn't. Most DDR3 RAM will fit DDR3 boards/slots but you can always check the Vendor Approved List which should be available under the 'support' section of the manufacturer's site.
