Just revived another 8Gb of Avexir ram to go with the 8 I already have, ordered through my order history so should be the same.
Installed and no boot so did mem check and booted into windows fine, my problem is I cannot run the XMB profile, when I check the timings my original set are CL9 1.65volts and the new set are CL11 at 1.5volts
Part numbers seem to be the same
If I manually set the frequency to 2133MHz I get all kinds of memory issues!
Do I just send it Back?
