Ram overclock and timing help
Permabanned
22 Dec 2010
Cambridgeshire
Is my RAM running at the correct speeds and timings?
Is there anything i can do to improve it?
I'm using this RAM:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-183-OC
And these are my CPU-z memory readings
I do not think anyone can help you because I am not sure anyone can see the image?
But since your sticks are the default ram settings on Intel board I would hazard an educated guess and say yes,
Short answer is Yes they are. :)
Edit. Needed to use quote to see the url link. The image is not working for me otherwise.
