Just built a new system for a friend, spec below:
BFG GeForce 7600 GT OC 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
OCZ ModStream 450w ATX2.2 Power Supply
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail
Asrock ConroeXFire-eSATA2 (Socket 775) PCI-Express DDR2 Motherboard
Corsair 1GB DDR2 Value Select PC5300 Dual Channel Kit (2x512MB)
(keeping his existing floppy drive, Seagate 7200.7 80Gb HDD and Liteon DVDRW)
The only way to fit everything into his budget was to get the 5300 RAM. But forgetting this when I put it together I set the timings in the BIOS to PC6400 ie 667Mhz instead of 533Mhz. Everything else at stock speeds.
It seemed to run fine in Memtest - let it run for about 8 passes before turning the speed back down for a longer run.
Do you think the ram could sustain that sort of overclock long-term, or am I better turning it back down?
Memtest said the bandwidth was 2798Mb/s at 667Mhz compared to 2650(approx) at 533Mhz. Is it worth the overclock?
Would I have to turn it down again if we decided to start clocking the rest of the system?
Thanks.
Thanks.
True, and remove spyware, viruses, etc...
