Hi All,
I don't know very much about mac's, but a friend of mine asked me to upgrade his RAM, so as you do i went and bought some RAM and bang! does not work
It is a Power Book G4 500mhz
currently with 512mb SDRAM 144pin
I bought 1Gb (2x512mb SDRAM 144pin SO DIMM 133mhz 3.3v)
I installed it and when i powered it up all i got was a beep and the standby light flashing, so i took them out and tried them one at a time, the same happened.
I then put the original RAM back in and it powered up fine PHEW!!!!
So my question is do you need specific RAM for a MAC and if so which
Thanks in advance
Thanks in advance
