Hi Guys,
I recently built a new system and have 2 problems with the following items:
Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard
x 2 - Corsair XMS3 6GB (3x2GB) DDR3 12800C9 1600MHz Triple Channel (CMX6GX3M3A1600C9)
When I run CPUZ it says my RAM is Dual Channel, and also have 12GB of RAM installed. But when I look in the BIOS and System Properties it only shows 8GB of RAM.
So I would like to make my RAM Tri Channel and also use ALL of the 12GB of RAM.
I've done the usual stuff, tested each RAM module seperatley, XMP & without XMP settings, reseated the CPU, tried some suggested different voltage settings but as of yet, no luck. Any suggestions more than welcome and I will try them when I get home this evening. If anyone requires more information I will provide it.
Thanks.
Thanks.
