RAM Question.
21 Apr 2013
Hi guys. I was just checking some things over in my BIOS and noticed this below..
https://ibb.co/rFV5PXZ
Does this mean one stick of RAM is running at 2922Mhz and the other at 2133Mhz or am I way off the mark here? I am running the XMP profile by the way.
The RAM is Corsair 16GB Vengeance 3000mhz
Cheers.
Hey Beady
Your BIOS shows it is set correctly at 2933 (~3000MHz the recommended stable setting for your setup - if it's the same build/motherboard from way back when.)
Ignore Task Manager - its reading the default profile memory setting.
You can download a useful tool called CPUz - if you want to look at other setting and also get clarification of all your memory settings within Windows.
Hey Beady
Hi Plec! Nice to see you're still around all these years later.
Thanks for the help as always, hope you're well!
