- 11 Mar 2005
Hi Guys,
I have a Dell Dimension E520, 2.67 GHZ Processor and 2gb ram.
I do a lot of CAD work and although the machine and graphics card I have aren't specifically designed for AutoCad it seems to run fine... I would however, like to double my RAM to 4GB, my questions are...
1) Can i find out the PC rating 4200, 5300 etc.. of my current memory easily??
2) If not can I mix and match??
I assume the memory in my machine will just be the generic ram that dell provide, so I'm just wondering if its possible...
3) Is it worth it?? Will I see much of a performance boost in Vista Ultimate??
EDIT
4) Does Vista 32 bit recognise 4gb?
The machine is mainly used for day to day office stuff and the odd game if i fancy it.
Any help gratefully received!
Cheers,
Tom
EDIT
Cheers,
Tom
