RAM RATIO?? HELP
Your running your Memory real clock speed at more than your CPU's real clock speed prob because of some Auto setting in Bios detecting Ram at 800mhz or 1066mhz (not sure hat Ram you have).
Well that means your Memory will prob be (depending on Mobo/bios) running at 800mhz and your FSB is only 266mhz in Bios and 1066mhz Quad Pumped in Windows (as Intels are).
Lower your Memory to 533mhz if you want 1:1 or Overclocked the FSB of your CPU.
