RAM Recommendation?
19 May 2013
Hey all,
I have around £130 - £160 to spend on some RAM, my motherboard can support speeds of up to 2133 MHZ (OC) and has 4 DDR3 slots. I guess I am looking for around 8GB.
Could someone please recommend some good ram that is within that price range?
I would be extremely grateful
Thank you :D
you can probably get 16GB for that price range. Going to 2133MHz doesnt give you the extra performance you might think it would or is there another reason for looking at that speed? Also do you need LP memory or normal size?
you can probably get 16GB for that price range. Going to 2133MHz does not give you the extra performance you might think it would or is there another reason for looking at that speed? Also do you need LP memory or normal size?
I am not looking for that particular speed for any reason, That is just the maximum my MOBO will support. I would like the best performance within that budget but a minimum of 8GB is what I require.
Regarding the size of the RAM, normal size is fine.
Thanks for taking the time :).
Its never a problem until it is lol if you know what i mean but yeah if height isnt an issue gor for team group or another good make like that (8pack cant you convince them to get more ripjaws stock plz!) :P
If you could link me to those particular RAM sticks I would appreciate it, I am not sure which ones you mean.
I have tried mate!!! The issue is not with anything other than the terms GSKILL deal with us on.
