Ram Settings? Help!
30 Jan 2009
Hi Guys,
Ive finally overclocked my
I7 920 4.0ghz @ 1.27Volts
21Xmultiplier
I have a Asus P6T SE Motherboard,
Now i need to sort out my ram, The ram i have Is Corsair XMS3 6GB AKA Here :http://www.overclockers.co.uk/showproduct.php?prodid=MY-169-CS
what settings can i set my ram to not being overclocked? EG Ram voltage ect shall i set it to DRAM Bus Voltage 1.64v? And leave the timings ect? as standard.
On everest it says i have it on
DDR3-1333 (667 MHz), 9-9-9-24 Timings
Or is that underclocking the ram where the standard is 1600mhz?
DRAM FSB Ratio 4:1
CPU Type QuadCore Intel Core i7 920 (Bloomfield)
CPU Platform / Stepping LGA1366 / D0
CPU Clock 4009.0 MHz (original: [ TRIAL VERSION ] MHz, overclock: 50%)
CPU Multiplier 21x
CPU FSB 190.9 MHz (original: 133 MHz, overclock: 44%)
Memory Bus 763.6 MHz
DRAM:FSB Ratio 4:1
Motherboard Chipset Intel Tylersburg X58, Intel Nehalem
Hope someone can help :)
Thanks Stefan.
