RAM speed higher is it actually better?
27 Feb 2009
Among the living
Hi,
I was wondering if higher ram speed is actually better when its high. For example the i7 920 D0 if i want to overclock it to 4.0GHz then would the 2000MHz ram run at 2000MHz or will it have to run at a lower speed?
Thanks!
Hmm, i spoke to someone who has the 2000MHz RAM *Corsair Dominator GT 7-8-7-20* he said that he couldn't actually run it at its full speed when he overclocked his i7 920 D0 to 4.3 on the Classified Motherboard. Instead he suggested the 1600Mhz from Corsair, which is half the price.
1600MHz
http://www.overclockers.co.uk/showproduct.php?prodid=MY-168-CS&groupid=701&catid=8&subcat=1389
So what if i had a choice should i go for the Dominator GT or something high *2000MHz? I wouldn't want to buy expensive RAM and all it does is perform about the same speed as RAM 2-3 times cheaper than it.
