RAM Speed Utility
18 Oct 2002
Liverpool, England
Is there any utilities apart from CPU-Z to check the ram speed?
I just got a core2 cpu and I am using DDR1 memory... I have the memory speed in the bios set at DDR400, but CPU-Z says that its running at 533Mhz... Its not really a problem as the memory is DDR500. I just wondering if CPU-Z is confused.
You could try Everest, that'll give you plenty of info, or SiSoft Sandra.
