new... ish.. to intel, lil help?
iv had reasonable success in the past with ivy but now iv just got a haswell 4770k setup.
with my ram set to 1333 or 1600 i can run my cpu at 4.4ghz stable, but if i enable xmp to bring the ram up to its rated speed of 2400mhz the overclock falls over and crashes. having a bit of a google i found this comment..
"The higher speed you run your ram at the lower your CPU OC will be"
is this true or am i missing something in the settings?
thankies!
thankies!
