Ram speed
12 Feb 2007
Doesn't matter what RAM you put in it will always run at speed matching the FSB, in this case your stock C2D is running 266Mhz FSB so DDR2 533Mhz.
With regards to mem speed i'm sure there is somewhere you can set it you will have to refer to your manual.
