Ram stick doa ?
2 Nov 2018
2x16bg corsair 6000 ddr5
CMH32GX5M2B6000Z30K
B650- Asus tuf gaming plus
initially machine would not post with static dram light on the motherboard. Tried both dual channel configs tna. Updated to latest mobo bios. Cleared cmos. Same issue. Tech thread suggested he'd had same issue and to use 1 stick only, install os then add second.
1 stick worked in B2 slot. Xmp also worked at 6000mhz after os and driver installs added second stick and again would not post. Used both sticks in B2 but only one would post. Waited 5 mins plus each time but dram light never cleared.
Any settings or alternative sequences I could try or is the ram doa?
