Right i recently put together a new system which to keep it short had some problems with the memory (or so it seems)
one bit of advice i was given was to look at the voltage across the sticks
my questions are as follows
how necesary/imperitive is it that the actual voltage/timings applied to the RAM correspond to the manufacturer recomended ones
for example the system i had problems with was
MSI P55-GD65 motherboard
OCZ Obsidian 4GB (2x2GB) DDR3 PC3-12800C9 RAM
im not sure i got the right wording/definition for it but the
"recomended settings" say
1.65V and timings of 9-9-9-24
the bios by default has both of these settings on auto
for the voltage this is 1.5v and the timings 7-7-7-18
