ram timings / oc help
1 Mar 2024
Leeds
i got this ram for my sons system, because of the RGB...
the CPU is a 7800x3d taken from my PC, we have the ram running on the second EXPO that is 6000mhz CL 38-38-38-78 but the main expo is 7200MHz CL 34-42-42-84
i was hoping for some help getting 6000mhz CL30.
the second expo only run's at 1.25v so i was hoping for some oc headroom
im not very good with ram and the timings any advice would be super
I use this as a cheat sheet and work from it if something doesn't pass stability testing, you'll want a program called zen timings and if you can start with the bullzoid EZ timings (top row far right of all the timing screenshots)
I would also start at VSOC 1.2v just to eliminate it and lower it once your timings are stable.
Just google Bullzoid EZ timings and you will find more information.
EDIT* Also just double check you have the RAM in the primary channel slots. often slots 2+4 these days
