Should be a simple question....
My ram is capable of 7-7-7-20 at 1333mhz, which it is currently at with FSB 200mhz. I am going to try acheive my current 3.5Ghz CPU speed using FSB instead of multiplier alone, to see if I can tell the difference.
I know that if i drop the RAM down to 1066, and up the FSB to 250mhz (if it will), this will put my RAM at 1333mhz again.
The question is...Does this mean the timings should still be set at 7-7-7-20, or will it mean i can use the timings for 1066mhz?
