Hi everyone,
When I was younger I used to upgrade my PCs all the time. It's been about 10 years since I have!
Last year I bought an Alienware 15 R4. In the description of the order, the RAM component reads:
370-ACRZ
8GB, DDR4, 2400MHz; up to 32GB (additional memory sold separately)
I want to upgrade to the maximum 32GB of course.
I understand that when it comes to Alienware laptops, some of the components are the PC versions. It's more like a flat PC than a normal laptop. The video card, for example is NVIDIA® GeForce® GTX 1060 OC with 6GB GDDR5, which does not appear to be any different from the version you'd get off the shelf for a PC. Correct me if I'm wrong here.
Anyway, my point is, when looking to upgrade my RAM, lots of guides say if you're using a laptop you need special tiny RAM.
For my Alienware, I really can't tell. I don't know exctly which brand I have. I'm going to replace them, of course, so they don't need to be the same brand of what I have.
I'd like advice on exactly which RAM to buy.
Any help is appreciated.
370-ACRZ
