Hi all,
Firstly, thanks for taking the time to help me out.
Okay, I bought my system from here (OCUK) and it was an overclockers bundle I think it was called. It was a Abit IP35 Pro XE, with quad core intel q6600 and 2 x 1 GB OCZ PC-8500 RAM. I bought it for gaming and it was the business.
I've had to rebuild the PC as I need it for a lab environment to study with. It's now running Ubuntu 64bit with 64bit VMware and a hypervisor program called dynamips (it emulates Cisco routers).
It's running a tad unresponsive due to everything going as apparently GNS3 (hypervisor GUI) and dynamips are quite bad for hogging RAM + I have two virtual windows servers running.
I would like to upgrade the RAM to help this and have some questions before I order. They are:
1) will extra ram help?
2) what kind/speed?
3) do they need to go in certain slots if they are bigger? I understand from searching that I should install them in pairs but I followed the instructions that came with the overclockers bundle and wonder that if I get two 2GB chips should these go in the banks that the current 1GBs are in and then Move the 1GBs to the currently empty slots?
4) Should I go for 2x2GBs or 2x1GBs? I know that's a tough one to answer but my work are paying so it's really asking will 6GB be used?
5) Any recommendation?
That's all I can think of? I'm fairly technical but not very good with hardware
. Any and all advice is greatly appreciated.
Thank-you very much!
Cisco Guy
2) what kind/speed?
. Any and all advice is greatly appreciated.Thank-you very much!
Cisco Guy
