RAM upgrade help
20 Jan 2004
Bristol
Hi
I have a Gigabyte GA-P35-DS3p rev 2.0 (http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2625 )and have decided to make the jump to Windows 7. I'm currently running 2 gb DDR2 6400 and want to upgrade as the board supports up to 8 GB (4 slots). The memory list form Gigabyte is not much use as it is mainly only 1gb.
I have been out of the upgrade loop for a while and need some advice as what to get, I would like at least 6gb as I do a lot of gaming and photoshop.
Could you please recomend me something from OCUK, money is realy not an issue as the DDR2 is relatively cheap.
Should I go 4GB (or 8) of 8500 or 8gb of 6400 :confused:
Many thanks
