- 19 Jul 2010
- West Oxon
ok, so everyone tends to have a favourite area of PC building and their knowledge tends to focus around that area...... RAM selection/knowledge is not mine
I understand the basics, and have a little knowledge that different board trace topography and dimm rank configurations exist, but have to go looking and gen up if I need to. In general i'd be working with some sort of room for error, and then just set xmp in the bios and let it take care of itself! occasionally i've had to play around with manual settings, but this is about where my knowledge falls off a cliff so to speak!
Enter my latest thing to upgrade/work on, a HP Pavilion Desktop 590-p0006na UK
https://support.hp.com/gb-en/document/c06210056
it's pretty much as per the specs on that page, with a couple of notable differences.
1. I've just installed an MSI GeForce GTX 1650 D6 VENTUS XS OCV1
2. This forced an upgrade on the PSU to one that actually had a 6 pin power connector for the GPU! and was more than a 180w (got a HP 400w platinum rated model - stupid expensive proprietary sized thing)
3. Installed RAM is one stick of 4GB 2666mhz (MTA4ATF51264AZ-2G6E) not 2400 as listed on the specs linked above.
So obviously on installing that card and PSU and seeing how it ran overall, i decided it needed a little boost, money/budget is tight, and obviously given what it is, there is certainly a tipping point where upgrading isn't worth it for the returns.
I've already picked up a 16GB Optane memory module (m.2) for £14 and now I need to do something with that RAM, I was genuinely surprised they still sold things with only 4GB in it, given what windoze is like for hoovering up resources!
The board has 2 Dimm slots, and a max of 2666mhz, I haven't been in the BIOS yet, but would expect minimal options, and I very much doubt if it would be happy running too far over 1.2v and as for any sort of overclocking forget it. The specs page for the motherbaord says 4 and 8GB Dimms supported, then says upto 32GB is possible with Windows 64bit
so i'm going to ignore that, and just assume that Dimm size options have moved on since this was built!
Obviously i'm looking at a dual channel configuration, I see no point in grabbing another 4GB module as that would only give me 8GB and I consider the minimum these days to be 16GB,ideally i'd like to fit 32GB but cost might be my limiting factor.
When it comes to speed selection, is it best I simply restrict my searches to 2666mhz modules, because anything faster, even if the BIOS has XMP 2.0, is likely to simply fail due to lack of support from the board, and as I said it's very unlikely to have any form of overclocking options being a H370 based OEM board, or could I buy faster and it'll simply run at the 2666mhz speed with some manual settings, and if so how would I know what timings to use, because those listed for whatever I get would be based on the faster mhz? I know they will likely default to 2133mhz initially but i'd like to run it at 2666mhz to eek out what i can from it.
Some Corsair modules have 2 xmp settings in them, are those generally the rated one and then a slower one that's more likely to be stable ?
So what would you guys fit ?
TIA
TIA
