- 13 Feb 2012
Just about order a few bits for my rig. I would like to order some more memory but I'm concerned it wont fit next to my Coolermaster V8, do any of you have these ?
I would like to buy 2 of these (with the idea of buying another 2 later on to total 32GB
) Ive chosen these as they seem to be well proven and have a good following.
http://www.overclockers.co.uk/showproduct.php?prodid=MY-314-CS
But the heat sinks look a bit high?
Does the fact that this is single channel matter? I know the speed can make a big difference. I just have some 1333Mhz Kingston cheapo stuff in atm, but I think my Motherboard (ASRock extreme 4 Gen3) can handle upto 2000mhz.
