RAM usage concerns
28 Jan 2011
Hey guys,
I have my setup on the go now but have another issue...
I have Ripjaw 8 Gig ram installed on the Windows 7 Ultimate 64bit..but I also put on Adobe Master Suite CS4..
Will I be able to use the full 8gigs included on these programs or because they are 32bit applications be limited to 4gigs (assuming I use that much anyway?)
cheers, RTJ
Yep, 4GB to each 32 bit application (2^32 bytes) maximum. On a real 32 bit system it is usually less than that, as the entire system needs to survive on 4GB (unless you have PAE :-) )
