RAM Voltage on a DS3?
7 Feb 2003
Hiya all
I recently upgraded to a gigabyte DS3 and a Core2duo 6600, I also got 2 gigs of Giel performance RAM. After readign a few articles on this forum I noticed the DS3's default voltage for the RAM (1.8) is wrong for the GIEL RAM (2.1). I have upped the voltage in the bois by +3 wich should give me 2.1? However when I use easytune 5 and check the voltages it says the ram is running at 1.8 volts and 666mhz?
Is this an easytune problem or is the mobo really not applying the volts. I noticed when installing most of my games that they cant be patched afterwards, I keep getting an error saying that the files have been altered? Could this be due to the RAM not running at optimum?
I have also flashed the bios to the newest wich I belive if the F7? This still only shows 1.8 volts in easy tune.
Thanks for any help as this is driving me nuts.
