Ramdisk or Supercache 5
6 Apr 2009
Liverpool
ok im greedy i bought 32gb memory yesterday now i am planning to use either a ramdisk or supercache...has anyone got any experience with using either or is their better software out there...any input would be great on this thanks...
I have tried Ramdisk and it works fine. However, as for the advantages of it, I only noticed the difference in video editing when I placed the raw video file onto the RAM disk. Everything else didn't feel like it improved at all.
ahhh so it shows up as a drive and you can use it like a normal hdd just wondering im bored and fancy messing about with something lol
It does indeed, so you can basically use it for anything, I've used a 10Gb partition for various things before now, including benchmarking and gaming
ahhh so load times will be quicker for gaming....sounds good to play with...can you uninstall them with out getting any problems aswell.
