Ramm issues
24 Jul 2013
Stoke-on-Trent
I can get the system to run if its single channel in dimm 3. (I cannot access dimm 1 due to the CPU cooler) in slots 2&4 dual channel I get nothing and a bios code 55, also to state the manual states that for dual channel you must be connected to slots 2&4
I'm beginning to wonder that it is, I really am hoping it isn't though. My motherboard is the msi Z87-GD65
The ramm is also corsair vengeance pro series 2133MHZ 8GB dual channel. They work individually in slot 3, slot 2 single doesn't work.
Problem solved, of you have this motherboard ignore the manual, dual channel works in dimms 3&4 for me not 2&4 as stated in the manual
