rampage formula undervolting?
6 Mar 2008
scotland (born in wales)!
hi
my problem is i set the vcore to 1.55volts and in hardware monitor in bios it says 1.48volts after reboot. i don't know which to believe...:confused:
thanks for help in advance...
That's normal. You can enable the Loadline Calibration option to close the gap if you feel the need to.
