Hi Guys,
I have two questions really:
1: Looking at programs such as CPU-Z, CoreTemp and RealTemp I notice at times beside my CPU it will say '1603.64 mhz or whatever then a few moments later it will say '2605mhz' it's usually when I open some kind of program. Is this some kind of normal feature Intel have on their CPUs to run at a low speed until needed? Should I keep this as it is or can somebody tell me a way to keep it fixed at 2.67ghz which is the default speed.
2: I was thinking about doing an overclock on it, nothing major I'd be pretty pleased with 3.0ghz or 3.2ghz to be honest. Does anybody have the Asus Rampage II and know of some settings that might let me achieve this without raising the voltage too high or maybe not at all? It's just I'm running the I7 stock cooler don't have an aftermarket yet.
My RAM is Corsair 6GB DDR3 XMS3 PC3-12800C9 1600MHz (3x2GB) if that matters, any suggestions would be much appreciated.
Thanks lads.
Thanks lads.
