Supports the Intel® Processors in the LGA1366 Package
Intel® X58/ICH10R
6 x DIMM, Triple Channel, up to 24G DDR32200(O.C.)/2133(O.C.)/2000(O.C.)/1800(O.C)/1600/1333/1066 MHz
3 x PCIe2.0 x16 slots, support x16; x16/x16; x16/x8/x8 configurations
- 2 x PCIe x1
- 1 x PCI 2.2
Multi-GPU NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
Storage 6 x SATA 3.0 Gb/s ; 2 x eSATA 3.0 Gb/s; 2 x SATA 6.0 Gb/s ports
LAN -Intel® Ethernet Gigabit LAN
- GameFirst
HD Audio SupremeFX X-Fi 2 Built-in with 8-channel High Definition Audio CODEC
-EAX® Advanced™ HD 5.0; THX® TrueStudio PRO™
-Supports Blu-ray audio layer content protection
-Supports Optical S/PDIF out ports on rear
IEEE 1394a 2 x 1394a ports (1 port at rear; 1 port onboard)
USB - 2 x USB 3.0/2.0 ports (at back panel)
- 12 x USB 2.0/1.1 ports (5 ports at midboard; 6 ports at back panel, 1 reserved for ROG Connect)
4-Pin Fan connector 8 x Fan connectors (1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional)
Software Kaspersky anti-virus (1-year full edition); ASUS AI Suite II Utilities
Features Extreme Engine Digi+, ROG Connect, BIOS Flashback w/ onboard BIOS Switch, Extreme Tweaker, iROG, ProbeIt, ASUS Q-LED, Loadline Calibration, CPU Level Up, Turbo V Evo, Q-Fan plus, LN2 Mode, Q Reset
Form Factor ATX Form Factor, 12”x 9.6” (30.5cm x 24.4cm)
