So I re flashed my rampage v extreme x99 bios using asus's ezflash2 and correct bios file. I was having some boot issues I thought it might fix.
It flashed correctly and said bios flash complete. System restarted and posted fine but went straight into a screen saying
"Bios is updating".
"Do not shut down or reset the system to prevent system boot up failure"
Was sat on that screen for 1 hour doing nothing so I shut it down. I then used the bios flashback via USB on the back which flashed correctly and the bios reset and posts. But I am still getting the same message and it won't go away.
I am tempted to flash an earlier version. I have flashed the bios before with no problems. I also set the system to default and ensured it was stable prior to flashing.
I am really stumped as it just stays on this screen and won't do anything else. I would have thought a sub flashback the flash the whole system and remove this message.
Any help would be greatly appreciated thanks
"Bios is updating".
