been having this issue for a week
if i wiggle or press on the 24 pin head where the cables go into the 24 pin the pc will power on if i press on it again the pc will power off and on and off lol
there does not seem to be a issue with the psu at all and wont require sending back
as the fix seems simple but i dont know what wire is causing it.
seems like a loose connection somewhere on end of it
here is a picture of the 24pin on the psu :
as you can see from the picture, its one of those 24 pin connectors that has a capacitor in it and when i press on that i get solid stable power if i let go of it the pc will randomly power off and on during windows load up.
sometimes if i press it and twist lol the pc will stay on and no issues
i need to figure out a way to fix this what do you guys recommend cause.... and what color connector do you think could be causing the issue is there a way to remove the cables from the connector and press them with a small set of precision plyers.... then put the cable ends back into the connector ??? freaking stupid issue this like ....... suprising this psu was bought from the same guy that sold me the watercooling system that was plauged with issues that had to be fixed
