Ran MemTest86 and it came back as "Fail"
Still doesn't answer my question.
What ram is it and what settings , xmp profile ?
If your unsure download cpuz and check.
Sorry about that
Here's what I found:
Memory SPD
DIMM # 1
SMBus address 0x51
Memory type DDR4
Module format UDIMM
Module Manufacturer(ID) Kingston (7F980000000000000000000000)
SDRAM Manufacturer (ID) Micron Technology (2C000000000000000000000000)
Size 8192 MBytes
Max bandwidth DDR4-2134 (1067 MHz)
Part number KHX2133C14D4/8G
Serial number F0170D98
Manufacturing date Week 19/Year 16
Nominal Voltage 1.20 Volts
EPP no
XMP yes
XMP revision 2.0
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 9.0-9-9-23-33 @ 692 MHz
JEDEC #2 11.0-11-11-28-40 @ 846 MHz
JEDEC #3 12.0-12-12-31-43 @ 923 MHz
JEDEC #4 13.0-13-13-33-47 @ 1000 MHz
JEDEC #5 14.0-14-14-35-50 @ 1067 MHz
JEDEC #6 15.0-14-14-35-50 @ 1067 MHz
JEDEC #7 16.0-14-14-35-50 @ 1067 MHz
XMP profile XMP-2134
Specification DDR4-2134
Voltage level 1.200 Volts
Min Cycle time 0.937 ns (1067 MHz)
Max CL 14.0
Min tRP 13.00 ns
Min tRCD 13.00 ns
Min tRAS 32.71 ns
Min tRC 46.46 ns
Min tRRD 3.75 ns
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 9.0-9-9-23-33-n.a @ 692 MHz (1.200 Volts)
XMP #2 10.0-10-10-26-36-n.a @ 769 MHz (1.200 Volts)
XMP #3 11.0-11-11-28-40-n.a @ 846 MHz (1.200 Volts)
XMP #4 12.0-12-12-31-43-n.a @ 923 MHz (1.200 Volts)
XMP #5 13.0-13-13-33-47-n.a @ 1000 MHz (1.200 Volts)
XMP #6 14.0-14-14-35-50-n.a @ 1067 MHz (1.200 Volts)
XMP #7 15.0-14-14-35-50-n.a @ 1067 MHz (1.200 Volts)
XMP #8 16.0-14-14-35-50-n.a @ 1067 MHz (1.200 Volts)
DIMM # 2
SMBus address 0x53
Memory type DDR4
Module format UDIMM
Size 8192 MBytes
Serial number EC170CAD
EPP no
XMP yes
XMP revision 2.0
AMP no
Max CL 14.0
Min tRP 13.00 ns
Min tRCD 13.00 ns
Min tRAS 32.71 ns
Min tRC 46.46 ns
Min tRRD 3.75 ns
You need to run memtest with just one stick of memory and then test the other stick by itself to see which one is causing the error.
