Hello guys,
For the past two weeks I have been experiencing random black screens followed by a failure to boot, the quick fix for this is to reset the CMOS, although it is inconsistent, and only lasts 15 minutes to 9 hours before the black screen issues re-appear.
What usually happens is either half of the screen starts flickering before it turns completely black, or it just goes completely black, the PC is still on and all the lights inside it are on but there is no output, there's also an light next to the EZ DEBUG LED that indicates GPU failure/error.
I have sent back my graphics card to Overclockers and they responded with 'no faults' , when I received the card back I re built my entire computer in a new case, cleaning out all the dust, re-applying the CPU thermal paste and doing a fresh install of Windows.
It lasted 9 hours before black screening, I tried to reset the CMOS, but it didnt work so I went to sleep, I came back the next day, reset the CMOS, it worked for 2 hours, and I have been repeating this all day.
If anyone has any thoughts on what could be the issue or any questions to help resolve this then I would much greatly appreciate it as this is really painful. I think I have to just RMA everything, but I would rather try fix the problem digitally before going through months of hassle.
rtx 3080
ryzen 5 3600 + mx-4 repaste
4x8gb 3600mhz
750w psu
b450m pro vdh max
corsair 4000d airflow
temps (idle)
cpu: 60-70
gpu 30-40
temps (game)
cpu: 70-80
gpu 60-70
rtx 3080
4x8gb 3600mhz
750w psu
b450m pro vdh max
temps (idle)
cpu: 60-70
gpu 30-40
temps (game)
cpu: 70-80
gpu 60-70
