Random BlueScreens
20 Aug 2012
Greater London
i don't know whether it's because i overclocked my cpu from 2.4ghz to 3.0ghz, (which isnt a huge overclock). i mean, it was fine and worked perfectly ok after i overclocked it, but 1 month on, i get these bluescreens every now and then. sometimes it gets stuck starting windows, and sometimes it bluescreens during games, so i have no idea whats causing it. any ideas?
also, i find that programs (e.g. 3ds max) appear to be running slower than normal, and sometimes the mouse sticks, and can be slow to respond. i checked my computer for viruses and found none.
Come on mate - people need a bit more info than that.
What's the CPU?
Board?
Memory?
PSU?
BSOD code?
http://www.nirsoft.net/utils/blue_screen_view.html will help you retrieve the last code.
http://www.xtremesystems.org/forums/showthread.php?266589-The-OverClockers-BSOD-code-list will help you diagnose the cause and guide you in fixing it.
okay... can't remember the BSOD code, but i'll tell you if (or rather when) it happens again.
i have 700W cooler master PSU
Asus P5G41T-M LX
8GB Kingston HyperX RAM @ 1333mhz
